Graphics card to a 2560 x 1080 and 200 Hz. monitor
PCguy132
Commendable
Apr 5, 2016
62
I have choosen between to monitors. One with 3440 x 1440 and 100 hz. and one with 2560 x 1080 and 200 hz. I picked the 2560 x 1080 with 200 hz. But now i am in a dilemma with which graphics card(s) i should pick for that monitor. I would like it to run over 150 fps. Do ou have some ideas?
Well it support g-sync, so if you're buying that monitor, go NVidia so you can take advantage of it. Otherwise it's a waste getting AMD that can't take advantage of a feature of the monitor.
Now you say you want a 150fps. In what? Some games, a 970 will do that, other 3x980ti's might not be able to hit that fps, so saying 150fps means nothing. We need context, and more importantly, what is your budget. Want 150fps in the witcher 3 with a $200 budget won't cut it.
In World of Warcraft, league of lengends, counter strike global offensive and games like that.
