So how would i connect a gtx 1050 ti which has DisplayPort , DVI-D and HDMI output while my monitor has VGA input. What converter could i use that is cheap and effective. Here is my monitor's ports. What is the second port? https://imgur.com/S1q1LlC
Either an active dvi-d or hdmi to vga converter is what you'll need, you couls also use an active displayport converter but those tend to cost more. That other port is usb.
