[SOLVED] Graphics card too big for case?
Jan 31, 2019
30
So i wanna buy a new graphics card its the 1060 palit 6gb dual but i think its too large for my case.
and i found it for cheap.
Prying and wiggling enough usually gets pesky rivets out. Its not fast or pretty, but if you have more time than money like me...
If you get a big adjustable wrench from the garage, you can use it kinda like a vice to manipulate the thin sheet steel. Try that if you run into a roadblock. If its particularly stubborn and wont de-attach, just smash it flat and shove it forward. And leave it there in the front of the case. I did that once and it worked fine.
Yes I have a drive thing. And i think i will do that
