Hopefully this is the proper place for this..
Anyway I have installed graphics cards before, but I get a little nervous when I'm testing with a modular PSU of unknown background. I had a chip on a GTX 980Ti flame out the first time I tried using extra connections on a past modular PSU so hoping not to duplicate. I had double checked proper cable connections, correct cables for the specific PSU, etc., but still it happened. It was a used 980 so hard to know.
Anyway I recently purchased some used components and want to test each out. I have an old PC in a big case with an nforce 680i lt sli motherboard that has space so it's easy to install and remove things. Running Windows 7 ultimate 64 bit, single DVD, and first of all I am using an old GTX 460 to test a used supernova 850 watt PSU. The 460 has 2 x 6-pin connectors on it. I was going to just use the cable that has one 6-pin, and one 6+2 pin coming off of it, but I've heard it's best to use 2 different cables, 1 each for each connector. I have another single 6+2 cable so I plugged in 1 cable to one of the 4 vga connections on the PSU, and the 2nd cable into a different vga connection. On the PSU. This seems right, but last time I did well you know... 980Ti toast. I've made doubly sure I've got the exact right cables into the exact right connections, but I am very nervous considering past experience. I realize that cables are NOT interchangeable.
Please advise. Thank you.
