Graphics card with 3x8 pin power - what PSU to use?
Kogure
69
Hello.
I recently found this graphics card, which looks absolutely amazing: http://www.kfa2.com/kfa2/graphics-card/hof/kfa2-geforcer-gtx-1080-ti-hof.html
But then I noticed the 3x8 pin power connector... While my 750W PSU does fit the 600W requirement, I've never seen a PCI-E power cable with 3 connectors. Would it be fine if I used 2x8, and hooked up an extra 1x8 from a second cable? Or would that be bad for the card?
I legitimately have no clue how to go about this.
Three 8 pin connections is no different than if you had SLI or XFire with two cards. As long as all the power plugs are connected back to your power supply you would be OK.
