Question Graphics card won’t fit
May 27, 2019
So basically my graphics card will go in partial but then where you bolt it to keep it sturdy it stops and I cannot put it all the way in the slot what do u do?
AllanGH
Estimable
Mar 10, 2019
2,552
533
3,240
81
Something is blocking it....possibly where the card bracket goes through the motherboard pan.....and move that card back up to the top slot.
Pull the right-hand case side off and try to guide the metal tongue through from the other side.
