Hi guys, first time builder here. My Gigabyte GTX 970 couldn't fit into my case as the lip thingy which is supposed to stick out of the back of the case wasn't bent at an angle enough to clear the edge. After some pushing and soving I finally got it to fit but now the card still won't go all the way in. There's a large gap where the two holes should meet to screw the card in and between the pins and the PCIE slot. I've tried applying some force but the card just won't go in any further. I'm using a Gigabyte Z97 X SLI motherboard and my case is a Corsair Carbide 300R Windowed. I'll put a link to some pictures so hopefully you can see what I mean. Thank you in advance for your help.
https://drive.google.com/folder/d/0ByljJMnQEaCuV0VyWC1DLXVTNGc/edit
