Graphics card won't fit into motherboard...help?!
Orcedi
20
So yesterday my new-ish pc arrived.
Specs:
Intel Core i3-4170
Asus Geforce GTX 750-ti 2Gb OC Edition
MSI H81M-P33 ( microATX, socket 1150)
Seagate HDD SATA 1TB 7200 rpm
2x Crucial Memory DIMM 4GB DDR3
Only problem is that the graphics card has PCI Express x16 slot while the motherboard has the regular PCI one.
Can I buy a new motherboard with PCI Express x16 and still keep the i3 and DDR3 ram? If so then what do you guys recommend?
Should I just buy a weaker graphics card? If so then which one?
Take note that I can't really afford an i5 and DDR4 ram.
LOL! That should do it!
That motherboard should have a PCI-E x16 slot, according to Newegg. It's PCI-E 2.0, whereas your card is PCI-E 3.0, but there should not be any incompatibility there. The literal connection does not fit into the slot?
OH MY FUCKING GOD!!! I didn't remove the plastic thingy from the GPU, I'm so stupid!!!
