graphics card wont fit may not be able to change case either
Aug 16, 2018
13
my pc is a hp elite sff pc and i want to put a large graphics card in it but it wont fit
and the case io is rivited in no room no suitable power connectors and a l shaped psu could anyone find the most cost effective solution thanks
Aug 16, 2018
13
a stock intel elite i 5 sff pc
motherboard--https://www.ebay.co.uk/itm/HP-657094-001-8300-Elite-SFF-LGA1155-Motherboard-/162492028111
psu -https://www.ebay.co.uk/itm/HP-COMPAQ-ELITE-8200-8300-SFF-240W-PSU-POWER-SUPPLY-613762-001-611481-001-OS1/401563222105?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D53531%26meid%3D510ee056c50e46b4b3224f22e3993df0%26pid%3D100754%26rk%3D1%26rkt%3D1%26%26itm%3D401563222105&_trksid=p2045573.c100754.m4842
actual pc ---https://www.ebay.co.uk/itm/HP-QV996AV-SB106-A3-Compaq-Elite-8300-SFF-Core-i5-3470-3-2-GHz-4-GB-250/401568904626?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D53531%26meid%3D3f734150eb8f495c8dd5c6cc87c1c669%26pid%3D100753%26rk%3D1%26rkt%3D1%26%26itm%3D401568904626&_trksid=p2045573.c100753.m4841
I am unsure about that particular pc but theres a good chance that your system uses proprietary connections so mounting it on a conventional case could be problematic. You could go for a new board+case+psu or just a new build all together. Whats your budget?
Similar threads
