B BLIND2788 Reputable Nov 22, 2014 22 0 4,510 Nov 22, 2014 #1 guyz plz answer which is good =>http://www.amazon.com/gp/product/B00KC90L08/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER. or http://www.amazon.com/gp/product/B00OG6FXZG/ref=gno_cart_title_3?ie=UTF8&psc=1&smid=A22WDFGR5I1U9E???
Solution Newbbuilder11 Nov 22, 2014 BLIND2788 : bro the r9 amd graphic can be installed in motherboard asusvmacimus vII lga socket 1150? and the gtx has ROG! u think still good the 280? ROG is a brand name with a OC in the card, even though the 760 is OC'd it's still slower than the 280, the Maximus VII will take any card AMD/Nvidia.
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Nov 22, 2014 #2 R9 280X is better. The GTX 760 ROG is expensive just for the brand ROG. Upvote 0 Downvote
Newbbuilder11 Honorable Feb 6, 2014 1,563 0 12,460 Nov 22, 2014 #3 BLIND2788 : guyz plz answer which is good =>http://www.amazon.com/gp/product/B00KC90L08/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER. or http://www.amazon.com/gp/product/B00OG6FXZG/ref=gno_cart_title_3?ie=UTF8&psc=1&smid=A22WDFGR5I1U9E??? Both are great cards, however, the 280x is faster. 280x is made to compete with the 770, so it's faster than a 760. Upvote 0 Downvote
B BLIND2788 Reputable Nov 22, 2014 22 0 4,510 Nov 22, 2014 #4 bro the r9 amd graphic can be installed in motherboard asusvmacimus vII lga socket 1150? and the gtx has ROG! u think still good the 280? Upvote 0 Downvote
Newbbuilder11 Honorable Feb 6, 2014 1,563 0 12,460 Nov 22, 2014 Solution #5 BLIND2788 : bro the r9 amd graphic can be installed in motherboard asusvmacimus vII lga socket 1150? and the gtx has ROG! u think still good the 280? ROG is a brand name with a OC in the card, even though the 760 is OC'd it's still slower than the 280, the Maximus VII will take any card AMD/Nvidia. Upvote 0 Downvote Solution
B BLIND2788 Reputable Nov 22, 2014 22 0 4,510 Nov 22, 2014 #6 thnx bro i go in 280x asus Upvote 0 Downvote
