D diaablo2 Honorable May 28, 2013 14 0 10,510 May 30, 2013 #1 i have an old pc with intel @945GCNL motherboard.... i previously had windows 7 os now i installed windows 8 os now i have low resolution of 1024X768 previously i had 1366X768 help me find graphics driver for windows 8...
das_stig Glorious Jul 24, 2009 8,281 30 46,040 May 30, 2013 #2 Since it's a i945G based motherboard using GMA950 GPU, you will have to use the Windows 7 driver in compatibility mode, as no driver for Windows 8. Try one of these, you will need to extract and manually install from device manager. x86 : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18223&ProdId=2115&lang=eng x64 : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18228&ProdId=2115&lang=eng Upvote 0 Downvote
D diaablo2 Honorable May 28, 2013 14 0 10,510 May 30, 2013 #3 das_stig : Since it's a i945G based motherboard using GMA950 GPU, you will have to use the Windows 7 driver in compatibility mode, as no driver for Windows 8. Try one of these, you will need to extract and manually install from device manager. x86 : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18223&ProdId=2115&lang=eng x64 : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18228&ProdId=2115&lang=eng Thanks for the suggestion .... i think it works...... i will inform if any problem comes.... Upvote 0 Downvote
