Graphics overheating in Thermaltake View 31tg
Dave_McG
Commendable
Apr 23, 2016
61
Is there some particular arrangement I can use of my 4 120mm riing case fans to help dissipate the heat from my graphics card?
I'm about to switch from the wraith cooler to my hyper 212 so that will help alot on the CPU,but not the GPU.My last case had 2 120mm fan spots on the cover so I could run air directly on the vid card.
Right now I have the cover off with a small metal fan blowing on card.It still hangs during boot with 92 code when used for awhile first.
I don't understand it clearly.
How many compatible fans do you have for your case?
How do you put them in it ? (intake, outtake, which places...)
Your case supports up to 7 fans. So you should not have overheating problem if you have enough fan and install them correctly.
I have 4 120mm riing fans for this case.I have 2 pulling air in front,1 pushing air in back,and 1 pushing air on top.I was thinking maybe take the top front fan and move it to the top to push air.That would give me 1 blowing into the HDD rack,1 exhausting out back,and 2 on top exhausting.The case has a bunch of holes in it to draw air in anyway.
