Graphics Problem In Quake 3
MD
86
Archived from groups: alt.games.quake3 (More info?)
I'm noticing in Quake 3 that some of the graphics aren't showing up
properly. Instead I'm getting a grid like area (it looks kind of like
the background for the holodeck area in Star Trek when the holodeck is
turned off). Also, some of the jump pads and portals are grey and
textureless. Is there some setting I need to adjust? Gameplay is
not hindered - the maps just look like shite. These maps have played
properly in the past. Has anyone else had a similar problem and fixed
it? System specs are:
1.3 GHz
256 Ram
128 Geforce 4 AGP Graphics
Any advice appreciated
MD
> 1.3 GHz
> 256 Ram
> MD
This is due to a custom .pk3 file in your baseq folder probably,a map or a
skin you've dl'ed and installed.
Remove 1 at a time until you find which 1 is causing the problem.
dont panic its not serious,,,its a gliche in the map...remove any new
installations recent to quake
"John" <john@nospam.com> wrote in message
news:416e21bc$0$54818$ed2619ec@ptn-nntp-reader01.plus.net...
>> 1.3 GHz
>> 256 Ram
>> MD
