Sounds like you have a heat problem. As that is an older system, I suggest you clean out the dust bunnies and hairballs, if you haven't already. Also, verify that all of your fans are indeed working. A can of compressed air would be very useful in evicting the crud that builds up in all systems. I recommend you do you dusting outdoors, by the way.
Good luck!
