Hello,
Recently my Philips 234CL started experiencing some problems. There are now green flickering lights on darker areas of images, videos and in video games. Here is an example :
I am sure these green pixels aren't dead since they can appear on every "darkish" surface but can also stay perfectly normal on the lighter, more bright images. I want to know if this problem can be solved since I'd rather buy a new GPU than a monitor. Also here is the list of tests I've done to see what's the problem...
Reinstalled monitor's and GPU's drivers, no effect
Disabled GPU to see if it's GPU's fault but even with integrated graphics I still saw these green pixels
Connected a different monitor and it worked just fine
Tried to use a different HDMI cable but no effect
Tried connecting monitor through VGA output but still same results
Connected the monitor to a different PC but still saw green flickering
