Green Tint on left side of monitor
TonyStark420
32
After loading up a YouTube video, a light green tint appeared on the left side of my monitor. I looked around and tried updating my drivers, but nothing fixed it. Need help asap.
EDIT: Okay it's not only down the left side, but not it's at the bottom of the screen too.
EDIT 2: I'm freaked out right now. The green tint at the bottom has now disappeared.
My brother-in-law's computer had a red tint at one point and it turned out to be a bent pin in the plug where the cable attached to the computer. In that specific case, however, the tint was across the entire screen. You might check both ends of the cable.
Since your problem is only on a couple of edges I'm guessing that something is going bad in the monitor.
Yeah, I removed the GPU and tested the Monitor with the Mobo port. It appears to be the monitor is rip. I've sued other cables too (VGA, HDMI, DVI). Thanks for the help.
