Green water loop coolants?
Mr_gomez
Do any of you know of any darker green coolants for a custom rigid tubing water loop that would look good with green led lighting. The rig will be wall mounted. The person I am building this for expressed a interest in the coolant looking like anti freeze if possible.
Hi,
There are many green watercooling fluids. I personally use mayhems as they are the only brand I have ever used and have had no problems. Here is a transparent one aka the X1 fluid: http://mayhems.co.uk/store/images/detailed/0/UV_Green_-_Black_-_Copy.jpg?t=1422355232
And here is a pastel one, it is brighter, but you can pick up mayhems green dye droppers that are compatible with the mayhems pastel range: https://www.google.co.uk/search?q=pastel+green+mayhems&num=100&espv=2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjY54KP2O3JAhXHDxoKHfEcAqQQ_AUIBygB&biw=1920&bih=979#imgrc=pZAvEjh1DEe_sM%3A I have never seen these in real life so you will have to experiment with a green dropper bottle to get the colour that you would like, if you...
Hi,
And here is a pastel one, it is brighter, but you can pick up mayhems green dye droppers that are compatible with the mayhems pastel range: https://www.google.co.uk/search?q=pastel+green+mayhems&num=100&espv=2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjY54KP2O3JAhXHDxoKHfEcAqQQ_AUIBygB&biw=1920&bih=979#imgrc=pZAvEjh1DEe_sM%3A I have never seen these in real life so you will have to experiment with a green dropper bottle to get the colour that you would like, if you get white mayhems pastel, then you can customise the amount of green to your exact liking.
Hope this helped, if you need anything else feel free to ask.
Thanks,
Simon
