My HP Photosmart 5510 printer makes a terrible "grinding" noise when switched on & also when cleaning the print heads. The carriage is stuck on the right hand side & will only move about 1 cm to the left but then something stops it moving any further. I have followed internet tips & got the top cover off as well as the 2 printhead springs & I can lift out the printhead. However the carriage still will not move to the left - something is obstructing it, but I cannot see what.
Is it possible to remove the actual carriage assembly from its tracks. This appears to be a frequent problem on this model & probably others, but I have not found any solution on the net.
The printer is out of warranty - I rang HP in the hope that they would offer some help but none was forthcoming - disappointing but not surprising!
