Question Gskill DDR4 Flare X PC25600 16GB CL 16 with MSI B450M PRO VDH MAX
naulia.adam12
hello, i'm planning on building PC with the ryzen 5 3600 and RTX 2060, the motherboard i'm planing to use is MSI B450M PRO VDH MAX and im planing to use the Gskill DDR4 Flare X PC25600 16GB CL16( F4-3200C16D-16GFX), i have a couple of question
1.does the ram compatible with the motherboard?
2.does the motherboard have a problem with XMP?
3.and do i need to activate the XMP feature to get 3200Mhz?
i already check on G.skill website and the MSI web for compatibility but only on g.skill web that said, the ram is compatible with motherboard on msi web i dont find the RAM model number
G.skill web: https://www.gskill.com/qvl/165/170/1564381714/F4-3200C16D-16GFX-Qvl
MSI web: https://www.msi.com/Motherboard/support/B450M-PRO-VDH-MAX#support-mem-19
Oh yeah if you want to see full list of the build here it is:
AMD Ryzen 5 3600
GALAX Geforce RTX 2060 6GB DDR6
MSI B450M Pro VDH MAX
WDC 2TB SATA3 256MB - Blue
WDC Blue PC SSD 500GB M.2 NVMe PCIe
be quiet! PURE POWER 11 600W
MSI Gaming Case MAG Forge 100R Tempered Glass
if it's not a bother, this is optional question, does my build plan is good enough?
