Hey there. I used to have a Asrock Z77 Performance but an accident happened and it went bust. All I could find was a Gigabyte GA-H61M-S1 (rev 2.2) to replace it while I have it reballed.
On its specs page (http://www.gigabyte.com/products/product-page.aspx?pid=4127#sp) it says it supports the following frequencies: DDR3 2200(OC)/1333/1066/800. I have a pair of 8GB-2400MHz G-Skill Trident X (F3-2400C10D-16GTX). Since the mobo doesn't go over 1333 normally, I want to enable that OC speed.
I figured that to reach 2200 all I needed to do was set the profile and timings on XMP. Set them to 10-12-12-31 @ 1.65V, but I can't get it to work. CPU-Z lists it as running at 789.1MHz.
Does anyone knows how to properly configure this? Thanks in advance!
