Gskill TridentZ 16gb 3200mhz(f4-3200c16d-16gtzr) compatible with asus prime x470 pro?
ProPlayerGR
595
42
19,040
Hello. Can someone look in this motherboard's qvl and tell me if this ram will run at 3200mhz with enabling docp? I can't look because I'm using a mobile phone. Thanks in advance.
yes
PRIME X470-PRO
Timing Voltage stock supported speed on MB
G.SKILL F4-3200C16D-16GTZR 16GB(8GB*2) SS 16-18-18-38 1.35V 3200 3200
Hi,
First excuse my english, is not my mother language.
My question is, will I be able to work with 2x(G.SKILL F4-3200C16D-16GTZR 16GB(8GB*2) ) at 3200 Mhz ?
I have a AMD Ryzen 2700x, and the MB listed above (PRIME X470-PRO )
and i have a G.SKILL F4-3200C16D-16GTZR 16GB(8GB*2) working very good at 3200 Mhz, but I want to upgrade to 32GB
Thank you for the great work you do in Tom's hardware.
