GSM1900 and GSM850 - maps?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.cellular.attws,alt.cellular.cingular (More info?)
Anyone know a third-party coverage map that shows AT&T's GSM1900 and GSM850
coverage (separately)? Should one have a world phone that only features
GSM1900 in the U.S., one would like to know where specifically GSM1900
coverage is with AT&T (not GSM850).
I am sure extensive research with their licenses for both cellular and PCS
would show this answer, but a quick fix would be nice.
Same for Cingular - do they have a map showing GSM1900 and GSM850 coverage
areas separately?
"News Hounding" <newshoundingREMOVETHIS@earthlink.net> wrote in message news:<6Qrnc.114$zO3.82@newsread2.news.atl.earthlink.net>...
> areas separately?
Third-party coverage maps are not simple to produce. Other than
required disclosure to the FCC regarding the satisfaction of certain
construction requirements, actual Cellular or PCS RF footprint can be
considered proprietary information. Wireless license maps, on the
other hand, can be readily produced w/ information that is a matter of
public record. On that latter count, you might find to your interest
the site that XFF & I have created.
http://www.wirelesswavelength.com/
Specifically, the following license maps hosted by the site are most
relevant to your question.
http://people.ku.edu/~cinema/wireless/cing-attws_800_850.html
http://people.ku.edu/~cinema/wireless/cingular_cel.html
http://people.ku.edu/~cinema/wireless/cingular_pcs.html
http://people.ku.edu/~cinema/wireless/attws_cel.html
As Cellular construction requirements are area-based, deployed
Cellular (800/850 MHz) coverage will closely mimic licensed coverage.
Conversely, as PCS (1900 MHz) construction requirements are
population-based, deployed PCS coverage will typically be confined to
concentrations of permanent or transient population - only a small
percentage of the licensed area.
The Cingular PCS map represents not only PCS licenses held by SBC or
BellSouth but also licenses controlled by Cingular affiliate Salmon
PCS & licenses acquired from NextWave - many of the latter two of
which are not yet in service.
As for AT&TWS, the AT&TWS PCS map is a task of overwhelming complexity
for me, hence is still yet forthcoming. However, it can be noted that
anywhere AT&TWS has a Cellular license, it also has an overlying PCS
license. Though the chronology is actually reversed, anywhere that
AT&TWS has deployed GSM 850 it also has GSM 1900. The latter, on the
other hand, is not necessarily true. In markets where AT&TWS controls
the PCS A or PCS B 30 MHz license, it is not a Cellular incumbent,
such that it lacks any 800/850 MHz spectrum.
In the regulatory filing seeking FCC approval of the Cingular-AT&TWS
merger, a combined coverage map was submitted that reflects the
deployed Cellular & PCS footprints of both companies. Bill Radio has
extracted that map from the filing & mirrored it on his site.
http://www.mountainwireless.com/cingular_att_coverage.htm
Though no distinction is made between 800/850 MHz or 1900 MHz, the
area-based construction of Cellular versus the population-based
construction of PCS is relatively manifest even on the macro scale of
the map.
Lastly, if you have questions about GSM 850, GSM 1900, or GSM 850/1900
deployment by either Cingular or AT&TWS in specific locations, please
just ask. Above & beyond the maps, my knowledge of what spectrum is
in operation where is fairly comprehensive.
Andrew
Andrew Shepherd
cinema@ku.edu
cinema@sprintpcs.com
In article <33e89561.0405091501.33f690a6@posting.google.com>,
> Andrew
Just read your post and have a beginner question.
My wife and I have ATT TDMA (I think that is right name, I'm no expert).
We are in Boston area but frequently travel to upper VT and NH and also
mid and Northern MI.
Over the years, 3 or 4 years, the ATT coverage has been good (digital
one rate). Now getting close to "needing" a new phone and trying to
decide whether to stay on TDMA or go to GSM. Anyway for a novice to
figure out GSM coverage in those areas (northern VT, NH and MI)?
Thanks.
Please send email to: nwhiii at yahoo dot com
Wow,
Thanks Andrew - great response and exactly what I was looking for...not to
read over the information at your links at that of BillRdadio's.
Thanks again!
"Andrew Shepherd" <cinema@ku.edu> wrote in message
news:33e89561.0405091501.33f690a6@posting.google.com...
GSM850
PCS
coverage
> > areas separately?
> the map.
> Andrew
> Andrew Shepherd
> cinema@ku.edu
If you're not on GSM yet I'd say that you should *not* switch to GSM
if you think you will spend any amount of time in upstate Vermont or
New Hampshire. You'll want a phone that's capable of analog AMPS
which you won't get with GSM. I really don't believe that the GSM
coverage is equal to TDMA and AMPS coverage once you get into a rural
area.
Your problem as far as getting a new handset is that you'll have a
very limited choice of handsets and they'll be pretty much plain Janes
with no neat features like you'll find with recent GSM phones. I
think the most modern Nokia phone offered is the 3560 with a color
screen. Other than that I'm not sure what AT&T is offering at the
moment. Keep in mind also that if someone has an AT&T model for sale
on ebay that may be another way to get another handset. You'll have
to realize though that the choice in really neat phones will not be
found in TDMA as that's a technology that has stopped being developed
with the major emphasis on bringing the GSM technology more up-to-date
and the choice of people with new service.
remove NONO from .NONOcom to reply
Not sure if AT&T would activate it, but a Nokia 6340i or SonyEricsson T62u
have AMPS, TDMA, and GSM all in one (albeit with no new snazzy features).
But for the utility of having a phone that does it all (at least on GSM -
the other two may be served just as well for backup purposes), these two
units appear to be the last hope.
"Joseph" <JoeOfSeattle@yahoo.NONOcom> wrote in message
news:m7lv90hqkqdcslcv0op12b952gmmkfppgo@4ax.com...
> area.
We have used this guide since his 4th edition. He is finally expanding to
updating monthly.
http://www.telecompublishing.com/WirelessTravelGuide.shtml
Very good book. Best $20 you can spend on the printed copy.
news:6Qrnc.114$zO3.82@newsread2.news.atl.earthlink.net...
GSM850
> areas separately?
In article <Rt2dnUc8weafUD3dRVn-sA@comcast.com>,
> updating monthly.
Looks like the typical exagerated maps the carriers give away. Maps
drawn by the marketing department that paint over all the dead spots
like none exist.
No Switch!.. Just was the Tustin, CA retail store told me. I moved my line
and 2 others to GSM, and still keep 2 Digital (five total). If you're in a
city, GSM is a deal if you can live with a few dropped calls. 1000 peak
national for $39.99 got me.
When I go rural, I use Verizon. I have an older Single Rate West
Do you mean "Northern Maine?" You said mid and Northern Michigan.
Michigan's Lower Pennisula has pretty good GSM coverage; Michigan's Upper
Pennisula is just getting GSM and it is all 850mhz GSM.
Stu
> area.
In article <ONeoc.6500$eH1.3239872@newssvr28.news.prodigy.com>,
> Stu
I did mean Northern MI; Traverse City, Petoskey, Harbor Springs to
Pellston.
The ATT GSM map shows coverage but when I called Customer Service they
said there was none. Strange.
Thanks for the info.
This could not be further from the truth. We use these books daily and have
found his maps to be right on and an essential guide at least on the analog
side. I work for Cellemetry and we use these to help customers program
radios and troubleshoot installations on fixed and mobile units. Very good
book.
What you want is a very expensive topo map that updates itself when the RF
fields and conditions change. If you know anything about the systems you
already know that this is RF and far from exact.
I had a customer fire off a registration in East Louisiana (the toe) and it
popped up on the MOBILE AL Cingular switch (SID 81.2) once A 3watt analog
control channel signal to be sure but it shows what these things are capable
of on a good day. BTW he was using a 5db gain mag mount antenna on a 2
story building facing the gulf. He switched to a Yagi facing inland and
popped up on the local switch.
"Røbert M" <rmarkoff@yahoo.com> wrote in message
news:rmarkoff-8A1FFC.08580011052004@news4.west.earthlink.net...
to
> > updating monthly.
> like none exist.
In article <mvCdnQj0oN9Pgj_d4p2dnA@comcast.com>,
> book.
I note with interest that you do not deny that dead spots are painted
over and not shown in these maps.
You are correct and I would have you read back at my post. There are always
going to be dead spots as RF is always going to have problems. If you think
that there is any system out there that is RF based that will not have
problems somewhere at sometime you are living in a dream land sir. It
cannot be done.
There are no maps that can totally accurately show the exact footprint of a
systems signal. They are in constant change. What you are talking about is
totally impractical and on their best day no carrier can show that kind of
accuracy.
"Dead spots" are just that. Somewhere that someone put up a building or
nature put up a darn tree that interferes with my cell signal. It happens
and no amount of hardware saturation will fix it and be cost effective.
news:rmarkoff-9BF184.09010712052004@news06.east.earthlink.net...
have
analog
good
> > book.
Hello Andrew (and all)-
Any word on when Oregon will 850Mhz GSM overlay? It's clearly not active
yet.
I say clearly not active because of the strong superiority of my TDMA AT&T
phones to the GSM phones I have access to.
-Dan
GSM850
PCS
coverage
> > areas separately?
> the map.
> Andrew
> Andrew Shepherd
> cinema@ku.edu
In article <LYSdnVsG0ZO54j_dRVn-vg@comcast.com>,
> cannot be done.
> accuracy.
There are known constant dead spots that carriers ignore with their maps.
Please don't try to pretend otherwise.
OK mr Troll. So what? The horse is beaten. Go to some other thread.
news:rmarkoff-5747A4.15143612052004@news06.east.earthlink.net...
always
think
> > cannot be done.
of a
about is
of
> > accuracy.
happens
In article <OqWdnSqIstuvFj7dRVn-sA@comcast.com>,
Throwing insults does not make the maps any better.
They are drawn by the marketing department
> always
> think
> > > cannot be done.
> of a
> about is
> of
> > > accuracy.
> happens
And your point would be?
news:rmarkoff-A9BAF2.09544913052004@news06.east.earthlink.net...
are
> > always
you
> > think
have
It
> > > > cannot be done.
footprint
> > of a
> > about is
kind
> > of
> > > > accuracy.
building or
> > happens
effective.
maps.
In article <TMednaJe473FEj7dRVn-jg@comcast.com>,
That all Carriers have violated their industry designed agreement to
make available maps showing where coverage is generally available.
> are
> > > always
> you
> > > think
> have
> It
> > > > > cannot be done.
> footprint
> > > of a
> > > about is
> kind
> > > of
> > > > > accuracy.
> building or
> > > happens
> effective.
> maps.
Archived from groups: alt.cellular.cingular (More info?)
And that means what to anyone but you?
news:rmarkoff-B57F74.11114413052004@news06.east.earthlink.net...
thread.
There
> > are
> > > > always
If
> > you
> > > > think
not
> > have
sir.
> > It
> > > > > > cannot be done.
> > footprint
> > > > of a
talking
> > > > about is
that
> > kind
> > > > of
> > > > > > accuracy.
> > building or
It
> > > > happens
> > effective.
their
> > maps.
