Gt 1030 240w power supply
Aug 12, 2018
So I have a core i5 16gb ram and 240w power supply I just bought a gt 1030 2gb gddr5 is that able to run with my power supply I'm worried I waisted 99$
It most likely will work as long as there are no other incompatibility issues.
That card only uses around 30W, so even if you have a 95W CPU, you're still not really pushing a 240W PSU. UNLESS you have a really, really cheap PSU. How cheap? Does it say "12A" for the 12V output on the label on the side of the PSU?
