Question Gt 1030 not working !!!HELP!!!
Apr 13, 2021
7
I have an Hp Elitedesk 800 G1 SFF with intel i5-4590, 16 GB RAM, and a 240W PSU. I also have an Nvidia Geforce GT 1030 in it, but in my PC doesn't recognize it. I do not know what is the problem.Please help!
Mar 3, 2021
39
18
45
240w psu is a bit light for a gpu and i5
GT 1030 is about 30w
i5-4590 should be under 85w.
240w should be enough.
Was it working before or is this a GPU you added to the prebuild?
Check the BIOS and see if your display is set to integrated graphics (iGPU) or PCI-e. Also check if there's an option to switch/enable/disable display type: AGP, PCI or PCI-e
hang-the-9
Did you check for the latest BIOS for the system? That old of one and an OEM may have an issue running that card.
There is also an issue with quite a few OEM systems don't supply full power through the PCIe slot, that will cause issues with cards that draw power from the slot.
Another thing, was this a new card? If not, was the card seen working before you tried to install it?
