GTA 5 is choppy on my PC ! Help? Specs listed
plrbear1028
460
I have high FPS, but it's still choppy and stutters in the opening scene.
Operating System
Windows 7 Professional 64-bit SP1
CPU
Intel Core i5 4460 @ 3.20GHz 38 °C
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 666MHz (9-9-9-24)
Motherboard
ASRock H97 Performance (CPUSocket) 37 °C
Graphics
VG248 (1920x1080@144Hz)
4096MB NVIDIA GeForce GTX 970 (EVGA) 37 °C
Storage
232GB Samsung SSD 840 EVO 250G SCSI Disk Device (SSD) 31 °C
931GB Western Digital WDC WD1003FZEX-00MK2 SCSI Disk Device (SATA) 35 °C
29GB SanDisk Cruzer USB Device (USB)
Optical Drives
ATAPI iHAS124 E SCSI CdRom Device
Audio
Realtek High Definition Audio
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
#45!!! yeah!
lets do some basics to make sure 'under the hood' is as we expected first turn off ALL OCing.
Did you install all Windows Updates? Including OPTIONAL except BING? Check them and repeat till ALL are installed.
Download and run Slim Drivers, install all the latest updates but you don't need to reboot until you do the last update
Go to www.filehippo.com, download Malwarebytes, go to CUSTOM Scan and set it to do a full system scan (by DEFAULT IT DOESN"T DO THAT, and AntiVirus doesn't pick up alot of malware) - this resolved almost ALL other similiar posts to date as most had Malware the AV didn't pick up.
Remove whatever AV your using and download AVIRA, AVG, Comodo or Panda go to CUSTOM Scan and set it to do a full system scan (by DEFAULT IT DOESN"T DO THAT) - this repeatedly has resolved alot of people issue relying on MS Essentials.
Repeat the AV/Malware scans till the system comes up clean.
Download AUTORUNS and turn off anything NOT critical on startup, so you don't need to run JAVAScheduler to check for Java updates everytime you start your computer for example. BE CAREFUL AND KNOW WHAT YOUR TURNING OFF BEFORE YOU DO IT.
Download and run MSI Afterburner, in the settings turn ON OSD, then go through and SET the stuff to 'watch' by enabling them in OSD (On Screen Display)
Now run some of the games that run poor, what temps are you getting when underload as compared to what you posted?
With MSI Afterburner Do you see anything funny that the CPU or other parts are maxing out (we are testing here not trying to WIN at the games, so if your screen is filled with readouts then just deal as we are just observing).
Do you see this problem when in SOLO MODE? Only when Multiplayer?
Check all the games you listed, and provide if there they ALL or just SOME are having this issue?
Open Computer, Can Air dust out the bunnies and use paint brush on the vents, coolers, fans, etc.
Go through and provide a response on each point, don't SKIP IT because "I ALREADY DID IT" , just try doing it again as of THIS post so we know NOW what is happening as compared to BEFORE you posted.
what?
You have a problem. you posted your concern here. Your problem is 'generic'. Any number of specific things can cause it but we don't know which one with your post. So here are the 'BASICS' to figuring out which one / multiple things can resolve the baseline problem. Please follow all the steps as outlined and reply with each one's response so we can determine A) did we find / fix something B) indicate more centrally what the CORE problem is. Just your post doesn't help as is.
Your system should be more than capable of running the game are reasonable frame rates.
Of course, the first step is to make sure you have all the latest drivers for your system.
Next would be virus/anti-malware scans to make sure your system is clean.
Next would be a check of background processes and what could be/should be shut down.
Beyond that, I believe we would be looking at hardware issues.
-Wolf sends
