GTA 5 low fps on GTX1060
MentosXtreme
Hi, i just built my rig month ano and decided to play gta 5 i've noticed that most videos on youtube they get 90 to 100 FPS on MSI Gtx1060 Gaming x 6gb which is same as my gpu. but the problem is im stuck on 30 to 40 fps. CAn someone help me fix this? Im running it on Very High settings (I also tried on Normal settings but still stuck on 30 to 40s)
Specs
I7 6700k 4.0Ghz
16Gb Ddr4 Hyperx 2400 RAM (x2 8GB)
MSI Gtx1060 Gaming X 6gb
MSI B150m Night Elf
500w Deepcool DE-500
Sorry but I have the game installed not in English. In order to don't change language, start, re-change, etc.... I send to you the content of the settings...
I literally spent days looking for a proper configuration. I use a 1070 though. Be careful with the settings, I can tell you what I use now that I get high fps. Remember to remove the post processing effects like blur and that aiming focus. Are really annoying and they do impact the fps more than other settings XD.
Oh yes please, might as well try your settings on mine. Can you tell me what settings are you using? for nvidia and in-game? Thanks in advance!
Sorry but I have the game installed not in English. In order to don't change language, start, re-change, etc.... I send to you the content of the settings file located in the folder C:\Users\YOURUSER\Documents\Rockstar Games\GTA V
If you still struggle to set it let me know and I will help you! XD
The Nvidia Control Panel Settings First:
Everything with default option except
Antialiasing - FXAA: On
Multi-Display/Mixed-GPU Acceleration: Single Display Performance Mode
Power Management Mode: Prefer Maximum Performance
Triple Buffering: On
Triple Sync: On
Then the settings.xml content:
<?xml version="1.0" encoding="UTF-8"?>
<Settings>
<version value="27" />
<configSource>SMC_AUTO</configSource>
<graphics>
<Tessellation value="3" />
<LodScale value="1.000000" />
<PedLodBias value="0.200000" />
<VehicleLodBias value="0.000000" />
<ShadowQuality value="3" />
<ReflectionQuality value="3" />
<ReflectionMSAA value="8" />
<SSAO value="2" />
<AnisotropicFiltering value="16" />
<MSAA value="0" />
<MSAAFragments value="0" />
<MSAAQuality value="0" />
<SamplingMode value="0" />
<TextureQuality value="2" />
<ParticleQuality value="2" />
<WaterQuality value="2" />
<GrassQuality value="3" />
<ShaderQuality value="2" />
<Shadow_SoftShadows value="5" />
<UltraShadows_Enabled value="true" />
<Shadow_ParticleShadows value="true" />
<Shadow_Distance value="1.000000" />
<Shadow_LongShadows value="true" />
<Shadow_SplitZStart value="0.930000" />
<Shadow_SplitZEnd value="0.890000" />
<Shadow_aircraftExpWeight value="0.990000" />
<Shadow_DisableScreenSizeCheck value="false" />
<Reflection_MipBlur value="true" />
<FXAA_Enabled value="false" />
<TXAA_Enabled value="false" />
<Lighting_FogVolumes value="true" />
<Shader_SSA value="true" />
<DX_Version value="2" />
<CityDensity value="1.000000" />
<PedVarietyMultiplier value="1.000000" />
<VehicleVarietyMultiplier value="1.000000" />
<PostFX value="0" />
<DoF value="false" />
<HdStreamingInFlight value="true" />
<MaxLodScale value="0.000000" />
<MotionBlurStrength value="0.000000" />
</graphics>
<system>
<numBytesPerReplayBlock value="9000000" />
<numReplayBlocks value="36" />
<maxSizeOfStreamingReplay value="1024" />
<maxFileStoreSize value="65536" />
</system>
<audio>
<Audio3d value="false" />
</audio>
<video>
<AdapterIndex value="0" />
<OutputIndex value="0" />
<ScreenWidth value="1920" />
<ScreenHeight value="1080" />
<RefreshRate value="59" />
<Windowed value="0" />
<VSync value="0" />
<Stereo value="0" />
<Convergence value="0.100000" />
<Separation value="1.000000" />
<PauseOnFocusLoss value="1" />
<AspectRatio value="0" />
</video>
<VideoCardDescription>NVIDIA GeForce GTX 1070</VideoCardDescription>
</Settings>
I really like the game with this settings. I only get drops in a certain specific grass zone outside the city near fort Zancudo at 52-54 fps with people and cars. Otherwise 60+ fps solid.
