Milan271 Commendable Jul 27, 2016 8 0 1,510 Jul 27, 2016 #1 I have a small problem that annoys me in GTA 5 cutscenes are in 9:16 not in 16:9 and then when cutscene ends it turns in 16:9 again. Does someone know how to fix this?
COLGeek Cybernaut Moderator Apr 6, 2009 59,590 5,330 184,340 Jul 27, 2016 #2 Where did you get the game from? That is an odd one. Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,590 5,330 184,340 Jul 27, 2016 #3 The OP indicated the game originated from Steam. I suggested contacting Steam customer support. If anyone else has a suggestion, please post. Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,590 5,330 184,340 Jul 27, 2016 #4 Are your video drivers fully up to date? Upvote 0 Downvote
Milan271 Commendable Jul 27, 2016 8 0 1,510 Jul 27, 2016 #5 Yes and that transmission is in 60 fps for some reason Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,590 5,330 184,340 Jul 27, 2016 #6 Do you have any GTA5 mods installed? Upvote 0 Downvote
Milan271 Commendable Jul 27, 2016 8 0 1,510 Jul 27, 2016 #7 https://www.youtube.com/watch?v=km78K0cG9vE Upvote 0 Downvote
Milan271 Commendable Jul 27, 2016 8 0 1,510 Jul 27, 2016 #8 No and I have never install them Upvote 0 Downvote
Milan271 Commendable Jul 27, 2016 8 0 1,510 Jul 27, 2016 #9 And the problem is also in singleplayer Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,590 5,330 184,340 Jul 27, 2016 #10 That implies even more an update/patch/install error. Have you tried uninstalling and then re-installing the game? Upvote 0 Downvote
Milan271 Commendable Jul 27, 2016 8 0 1,510 Jul 27, 2016 #11 I will try it know and if that doesn't work I will install it on another PC Upvote 0 Downvote
Milan271 Commendable Jul 27, 2016 8 0 1,510 Aug 7, 2016 #13 I've found out that many ppl has same problem Upvote 0 Downvote
