Gta 5 problem. weird green flashes on screen and crashes. err_gfx_d3d_init and display driver has stopped
dudupro
167
So theres some pictures ill be sending afterwards, i can play like couple minutes and then those random green things are flashing and then the crash approaches afterwards. Is it because of my Gpu is problemy? temp is okay, other games are fine, Gta runs on 50fps on veryhigh grpx, i've tried with lowest settings also .
Specs.
Grpx: amd r9 280x
Cpu: Amd phenom II x4 965 3,4ghz.
8Gb ram
Win 7 64bit
http://imgur.com/a/oNotZ
it sometimes flashes some specific objects, but sometimes randomly flashes over screen.
and it sometimes says error " Err_gfx_d3d_init" i have googled it, many gta players have the problem, but whats up with the green thing on the screen? And sometimes it doesnt hit the error.
Best wishes
dudu
That looks like video memory corruption. That kind of corruption doesn't usually cause a crash though, but a too-high clock speed usually does. Are you overclocking at all? If not, what specific model is your 280x? Some factory overclocked models from certain vendors have been known to occasionally ship with too low a voltage to run the higher-than-reference speeds and may require either downclocking or overvolting to compensate.
it throws me this too, which i think is a problem
