Hello,
I recently started playing GTA5 on the PC about 3 weeks ago. I play it primarily online and the game runs really well when I am playing by myself (64fps with vsync on 60% GPU load). When I start playing with friends though the game starts to fluctuate heavily on the fps as low as 30 and increase the GPU load to 100%, and while it is doing this the game is lagging heavily for all parties involved. It rubberbands badly and they are seeing me crash into things that I don't touch and vice versa depending on who is driving.
I have been able to fix it three times where there is no lag between me and my friends, but after I turn off my computer, then turn it back on, the problems come back, and the prior fix no longer works.
So far I have tried:
Opening the ports recommended by rockstar on the router and setting my IP address as reserved (This worked until I turned off my computer)
Turning off the firewalls on the modem/router combo.
Using a separate router from the modem/router combo from comcast and opening those ports.
Made sure the new router was up to date on firmware.
Setting my IP into the DMZ.
Unplugging the projector from the GPU and restarting ( Second fix).
Completely wiping the GPU driver and reinstalling it (Third fix).
Uninstalling and reinstalling GTA 5.
Installing GTA 5 onto the SSD.
Turning Vsync on and off
Adjusting graphics settings from very high and down.
Tried running the repair tool
Alt-tabbing in and out of the game
Changing the screen from full to windowed/windowed border less.
Tried older GPU drivers
Checked power settings and re-seating the card.
I am sure I did more, but that is the gist of it. When it was working in its prime for those couple of fixes I was getting around 150FPS with vsync off. My net speeds are 120D 10U. The projector was being used as a second monitor. Fans are working, and temperatures are within normal operating range.
Specs:
Asus z97-a
GTX 970
i5 4690K
8GB DDR3 1600MHz
Thanks in advance!
Specs:
Asus z97-a
GTX 970
i5 4690K
8GB DDR3 1600MHz
Thanks in advance!
