Gta 5 specs between minimum specs and recommended specs...
4
Does the minimum requirements suitable for gta 5 as described on many websites. Please tell me a graphics card a little better than 9800gt. So there is no hesitation of playing gta 5 on core 2 quad q6600 with 4gb ram. Please tell me i am hesitated. Thank you.
lucaswyrm
37
Well, With Wolf Comment You Could Do That, Then GPU Will Not Be BottleNeck Even In High Settings, If You Take 1030, You Should Add Extra 2 GB Of Ram, So There Would Be No High FPS Drops...
Apr 19, 2018
4
MERGED QUESTION
Question from aliabdullahj190 : "Can i run gta 5 smoothly woth following specs ?"
Can I play GTA 5 smoothly with following specs:
Core 2 quad q9550@ 2.83ghz
Ram 6gb
Asus gtx 650 1gb
What will be the psu required for asus gtx 650 1gb in terms of watts.
lucaswyrm
37
Recommended Is 400W, But IF You Have 300W+ It Is Fine...
