GTS 250 Low Source Engine FPS
Yougo
I recently upgraded my PNY 9800GT to an EVGA GTS 250. I play a lot of source games and used to get 150 FPS or so on my 9800GT. When I first used the GTS 250 I was getting close to 200 FPS. For some reason now, I am getting around 20 FPS. I have no idea what is happening. Any ideas?
CPU: AMD Phenom X4 9150e
RAM: 4GB RAM
OS: Windows 7 32bit Ultimate
My 3DMark Bench: http://service.futuremark.com/home.action?resultId=2302414&resultType=19
First I'd check the temperatures of your GPU, it may be overheating. Secondly I'd check the case for any dust which may be restricting airflow, causing the GPU to overheat. Lastly, I'd uninstall all nVidia drivers, completely remove them then install the newest ones available.
Yougo
It runs pretty steadily at 60C while in game. I reinstalled the drivers like you said and will test it out in the morn. Thanks for your reply.
LuigiVN
150
Yeah, probably a drivers problem. Did you install any other drivers recently? That GTS 250 should run like a charm in all source games, even at 1900 x 1200
