GTX 1050 Ti OC no 6 pin power connector
jacksonb
12
I just got my Gigabyte Windforce GTX 1050 Ti OC, and I thought it was supposed to have a 6 pin power connector for better overclocking capabilities, but it doesn't. Will I still be able to overclock it well in Afterburner?
the one i have doesnt have one
Then it's not the Windforce OC model.
The Windforce OC definitely has a 6-pin auxiliary power connector.
The vendor has either sent you the wrong one or you ordered the wrong one.
Mine is definitely windforce, but the model name is just GeForce GTX 1050 Ti OC 4G, is it possible that it just uses the windforce cooling system, but is a different model without the 6 pin power connector?
The card I linked in my earlier reply does have the 2 fan Windforce cooler, but isn't actually the Windforce edition card. Also, it does not come with the 6 pin connector - this is likely the card that OP has.
