gtx 1050 ti only running low
May 12, 2018
hey there i just recieved my laptop (lenovo y520) with a gtx 1050 ti it had nvidia drivers when i first
ran it and i changed 3d settings from the nvidia control panel to the gpu not the integrated one
when i ran heaven and engine benchmarks it was running at 1900 graphics and 2500 memory clock i updated the nvidia drivers and restarted the pc now it runs with the same graphics but at 3500 memory clock
[https://imgur.com/a/YLlTwTJ score at 900p
and this is how my msi afterburner looks
[https://imgur.com/a/fSK7hi6
how can i make it run at full power?
My self a Gtx 1050 TI user !! My graphic card runs 1700mhz base clock and 3567mhz memory clock at 100 percent usage in 1080p resolution while i am gaming which are pretty decent...
My self a Gtx 1050 TI user !! My graphic card runs 1700mhz base clock and 3567mhz memory clock at 100 percent usage in 1080p resolution while i am gaming which are pretty decent and as far as ur case goes ur numbers are good enough for the resolution u have !! By increasing the firepower if u referring to overclocking i wouldnt recommend doing that in the case of a laptop cause it will generate a lot of heat if u do that whci wont be good for the gpu and for ur laptop as well !!
