I just bought a GTX 1050 TI and i tried to connect it and i uninstalled all of my amd drivers beforehand then installed the nvidia drivers and nothing happened.
The fans of the 1050 wasn't spinning or active
I suspect that the problem could be my power supply that isn't giving the card enough power.
My specs:
Windows 8 Pro
CPU:Intel Core i7 2600 3.40GHz
Ram:6.00GB DDR3
Motherboard:Foxconn 2ABF
GPU:ATI RADEON HD 7500 SERIES (old card)
the power supply on my computer doesn't specify the Watts on it and the manufacturer doesn't either show the amount of watts.
i'm new to pc so i hope some of you could help me here. Thanks
My specs:
Windows 8 Pro
Ram:6.00GB DDR3
