Gtx 1050ti pentium G620 low fps
Sathvick
43
my comp..
intel pentium G620
6gb ram
gtx 1050ti 4gb
before i used to gte around 20 to 50 fps with my geforce 210
now after upgrading to a gtx 1050ti my fps is around less than 40
i think there is some settings problem which i am not able to identify....
anyone pls help....
The main problem there is your CPU, an Intel Pentium dual-core (Sandy Bridge)with no turbo Boost, no hyper-Threading is holding back the performance on your new 1050Ti.
Solution, upgrade your CPU to a newer Skylake or Kaby Lake CPU
Edit: Plus a 8GB of ram will help a bit
The first thing people usually ask is if you removed all your old drivers for the 210. DDU is often recommended, then reinstalling the new card. The second is to ensure all components (CPU, GPU) are running at their correct speeds. Finally, check to see if any in-game settings have changed going from one card to the next.
And drivers, did you make a clean install with the new GPU?
Counter-Strike: Global Offensive lists DX9 as a minimum and DX11 as recommended, so has codepaths for both.
The heavier load on the CPU from the DX11 path means Source Engine defaults to 3 threads, although you can specify 4 (with -threads 4). This doesn't help you with your 2-thread CPU so drop to DX9 mode.
