• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
GTX 1050ti Problems
atiqx
Proper
Aug 29, 2018
52
I have a Corsair 270r case with a ASRock H310M-HDV Motherboard with a GTX 1050ti and it just doesn’t seem to fit, i’m confident that the parts are compatible (this is my first build and i’m having severe troubles)
atiqx
Proper
Aug 29, 2018
52
I got It to fit just a stupid error of mine, the main problem now is that the GPU fans are spinning but it's not detected I have 450 PSU and the GPU says that the minimum amount is 300w so it should be enough power. There is no PCI Slot as it runs off the mother board, in the bios settings there is no setting to enable it as the main graphic option. I have no clue what to do. Some people say that my CPU pin may be bent but if that was the case wouldn't the motherboard HDMI output not work? Should I try a VGA cable, it probably wont make a difference, but it is worth a shot. DO you have any suggestions?
atiqx
Proper
Aug 29, 2018
52
Do you have any other suggestions?
clutchc
Herald
If you have the video cable plugged into the card and not the motherboard port (as norcalsc said), then it should work. Do you get any display at all when you turn on the PC?
What video cable are you using?
zebarjadi.raouf
Commendable
Jul 10, 2018
864
280
Reinstall latest Nvidia drivers. (install if you don't have)
Try another port/cable.
Test on another PC. It rules out every problem you might have
Does your BIOS detect the GPU? There should be a section for all parts connected. If it does, that's good. If it doesn't, you have to take it out and install it again. Also, BIOS calls it PCI-E (Dedicated, Discrete, ...) when selecting preferred output.
atiqx
Proper
Aug 29, 2018
52
When I plug the HDMI cable into the GPU I get a error on my monitor saying"No Signal" But when I plug it into the Motherboard HDMI it works like a normal computer everything works fine, but I want the GPU for better gaming performance
atiqx
Proper
Aug 29, 2018
52
I wish I had another PC to try it on but I don't I could try a VGA cable but I doubt it'll work, but it's worth a shot. NVIDIA drivers don't work Like I said it says it doesn't detect the GPU (Didn't Meet The System Requirements)
clutchc
Herald
If you can plug the cable into the MB port and get a display while the GTX 1050 Ti is in its slot, then the card isn't making good contact, or the card or slot is bad. Normally, when the BIOS sees a video card in the PCIe x16 slot, it disables integrated video.
atiqx
Proper
Aug 29, 2018
52
I have tried everything, I even forced my drivers to install by changing the settings in NVIDIA, but when installing it froze and didn't respond, there is no PCI slot in my GPU, I just ordered a new one with a PCI slot though so ill see how that goes.
clutchc
Herald
Had you ever run DDU while the PC was on integrated video (no gfx card in the slot)? It does a pretty thorough job of cleaning the registry and other places Nvidia and AMD hides their files. Might be a corrupt install that left you messed up.
atiqx
Proper
Aug 29, 2018
52
There is no integrated graphics it's just called Microsoft Display Adapter, I ordered an ASUS 1050ti and it arrives tomorrow then i'll find out if the works. I think my other one just came faulty? should I send it back..?
atiqx
Proper
Aug 29, 2018
52
Intel Core i3 8100
atiqx
Proper
Aug 29, 2018
52
Okay, so I got my new GPU today (ASUS GEFORCE GTX 1050ti) Boom same problem no display and this time the fans start for a couple of second and then stop...
clutchc
Herald
The fans stopping probably isn't a problem. Many cards have zero decible fans that turn off blow ~60C. But the lack of display is troublesome. Sure you didn't forget to move the monitor's cable to the gfx card's port?
atiqx
Proper
Aug 29, 2018
52
Yeh man still doesn't work, just no display, pretty sad I dont know what to do
atiqx
Proper
Aug 29, 2018
52
Yes, I do have a couple of friends but they live like across the city though, but I can give it a go, i'll ask today, like I got my intergrated graphics to work, there not to bad can run fortnite 120 frames, but other games do have troubles, I think it might be my MOBO just because I got two GTX 1050ti's on one of them the fans spin but on the other one it doesn't and they both get no signal. But then again my MOBO HDMI does work, so Im confused, Maybe it's a faulty PSU??
atiqx
Proper
Aug 29, 2018
52
Yes, I run 120fps on 1024x768 100 3d resolution low settings with an iGPU, its pretty crazy but I have wasted money on two GPU's, I dont even get a signal, I dont know what to do...
Similar threads
