With these specs :
GTX 1060 6gb
I5 6400
16 GB RAMS
I'm having issues about my FPS with these specs. I'm getting around 30-50 FPS on fast settings (low) . Is there something wrong with my PC? Are there any solution? 🙁
Actually my friend, those are close to accurate FPS rates you should be getting with that setup I think. Not too sure about how strong the 1060 is compared to the 1050ti but I think that should do it
What settings are you playing on? Did you plug your monitor into your GPU slot and not the integrated Intel graphics? Did you install drivers for your GPU? Are you using your GPU for mining? Did you install anything fishy lately?
I’m playing on fast settings, i already plug my monitor into gpu and everything is updated. I never use my gpu for mining, and never installed anything fishy. Is there something wrong with my pc? 🙁
Did you use AMD before Nvidia? It might be that some drivers were left over. Use DDU to uninstall them completly (both Nvidia and AMD if you have them) and then reinstall fresh Nvidia drivers
