GTX 1060 little help
Gatis Laugalis
27
I bought GPU today, went to home. I unninstaled all AMD drivers (Old GPU HD7770), then i replace GTX 1060, and my VGA adapter doesn't support or what, i have LED monitor, and what i can do?
Specs: I5 6600k, 16GB Ram DRR4, ASUS Z170 Pro Gaming, Fortron Hyper S 700W, Samsung EVO 250GB, WD 1TB 7.2k.
Most GTX 1060s don't have the analog part (some manufacturers may make them) in the DVI port so you can't use a normal VGA adaptor. You can get an active adapter which will do what you need but they are more expensive. If you can I suggest returning the card and buy one with an analog output.
A bit expensive, it's called Gembird HDMI to VGA adapter, costs 18,44 EUR (Eastern Europe). Sorry i'm bit wrong write about my monitor, and custom gpu is GTX 1060 6G Gaming Strix - It does have HDMI , DisplayPort , DVI, VR HDMI
Since your monitor has an HDMI port and the 1060 has an HDMI port, just get an HDMI cable. It will be cheaper than buying an HDMI to VGA adapter and you won't lose any picture quality.
i got the same problem, my monitor has DVI(I) and VGA i bought DP to VGA adaptor and no image is sent to screen, any idea how i can fix it?
Use a Dual Link DVI cable, and go DVI to DVI.
Ok first I put the graphics card all the way in but it still moves upwards. I don't know how to secure it. Secondly when I connected the card with an hdmi cable and connected it to the tv since my monitor does not have an hdmi port only the d-sub port. I have an hp 700-406 pc by the way. My tv screen shows nothing only no signal.
My graphics card is an ASUS gtx 1060 rog oc 6g it has 2 html ports, 2 display ports and one dvi port. Do I need to connect all of them to make the screen show up and does it matter if the card is not secure all the way?
It's ok I just bought another dvi to hdmi cable to connect it to the m on monitor. Now I have another problem. My internet speed is going very slow. When I didn't have the card installed, it was fine. When I installed it my internet went 18mbps to 1 or 2 mbps which is ridiculous. My processor is amd a10 7700k which it bottlenecks because it's a slow processor. I didn't uninstall my and drivers from the old gpu which was Radeon r7 that was is built into the mobo. When I ran Radeon settings, it said no amd drivers were found or not going properly. I'm guessing the drivers were all deleted because it detected the gtx when I went to device manager then display adapter. I also used a driver program to uninstall all and drivers but that didn't work. Can you please tell me what is going on with my internet speed? Its not supposed to be this slow.
