Okay here's what happened.
Mobo: ASUS P8H61-M LX3 PLUS
CPU: i3-2120
RAM: HyperX 8 gb
PSU: Thermaltake SE 730W
HDD: 500gb WDblue
OS: Windows 7 64bit
Previous gpu: MSI GTX 730
New gpu: MSI GTX 1060 (tested from the shop so its not dead)
Room temperature is fine
So my computer is running perfectly, i just want to upgrade my gpu to play aaa games thats why i decided to buy a new gpu. So after I got it, these are the steps that i made:
1. Device manager
2. Uninstalled gtx 730
3. Shut down pc
4. Take off gtx 730
5. Did some dusting (pcie slot covered)
6. Plug in the gtx 1060 in the pcie
7. Plug the 8 pin power (properly plugged from the psu)
8. Plug the monitor on the card (i only have vga cord so i used a vga-dvi adapter to connect to my card, monitor doesnt support hdmi)
9. Boot up my computer
Then there is no display. The light indicator of the monitor stays on "standby"
Orange - standby, just plugged in (similar to no signal)
Yellow - on
My diagnostics:
1. Removed the gtx 1060 and placed my old. It booted up perfectly.
2. During black screen, i tried spamming alt+f4 and enter, then my pc turned off (the lights goes out and fans stopped spinning)
3. Cleared the cmos
4. No card - msconfig - boot (safe minimal) - apply. yes. not restart. Shut down - put card in - still black screen (on standby mode)
5. Tried connecting both the monitor cable to mobo with card and directly to card
6. Uninstalled all nvidia programs using "add or remove programs"
Help. Im panicking I cant afford to let my money be wasted like that 🙁 (((
CPU: i3-2120
RAM: HyperX 8 gb
HDD: 500gb WDblue
OS: Windows 7 64bit
1. Device manager
3. Shut down pc
4. Take off gtx 730
Yellow - on
My diagnostics:
3. Cleared the cmos
