GTX 1060 requires 6-pin connector but has 8-pin connector?
bbdare
17
I recently purchased a PNY GTX 1060 3GB Overclocked at 1582 MHz (model: Geforce GTX 1060 VCGGTX10603XGPB-OC-BB). On the back of the box, under the "Minimum System Requirements" section, it states "One 6-pin PCI Express supplementary power connector", however on the card itself, there is only an 8-pin connector. Is this just a misprint, or am I able to get away with using a 6-pin connector?
It is possible it may work but I do not encourage you to run a 6pin if it has an 8pin. It could potentially undervolt the card and cause issues when rendering, it may not work or cause damage from undervolting the components (though unlikely to I would think).
