GTX 1060 TURBO ASUS - Problem!
BigBoom
Commendable
Aug 31, 2016
Hello to all.
Problem #1
I got Asus gtx 1060 6gb turbo and replaced my old radeon HD7850.
I plugged in my new card and all went fine (I used DDU to clear old drivers) until I installed nvidia drivers. Then, when I restarted my comp, my monitor displays strange green-blue vertical lines and I can't see boot screen and can't see bios and windows, nothing. I then get back my old card and all is fine again. So I returned card to the store and waited for the replacement.
Picture from this problem here (green lines was replaced by this artifacts when windows started, see image):
https://pictr.com/images/2016/08/17/9462cdcf6c076001bd4739366c3f4976.jpg
Problem #2
Store sent me new card - same model.
Again, I plugged in my new card and all went fine (I used DDU to clear old drivers) until I installed nvidia drivers (from official site - latest version 372.70). Then, when I restarted my comp, my monitor again displays strange green-blue vertical lines and I can't see boot screen and can't see bios. But now when the windows starts, all is fine, working well. I am using hdmi connection.
I didn't test it on different comp yet or with another connection.
My motherboard is GA-H61M-S2-B3 -> http://www.gigabyte.com/products/product-page.aspx?pid=3917#ov
Now, did they sent me the same card... I don't know, this was in a new package... or I have some other problems, don't know. Please if someone have a clue what is this, let me know.
All the best
Make sure you have the latest bios of your motherboard installed (according to the change history they had some problems with nvidia cards)
Ifi nothing else happens you propably have to change the motherboard...
