So just a quick summary:
GTX 1070 - DVI and HDMI ports
my monitor - DVI and VGA port
integrated graphics card - DVI, VGA, HDMI port
my tv - HDMI
monitor-to-pc cable: DVI
So I just got my GTX 1070. I put it in the pc and through my integrated graphics card I installed all drivers.
Then I unplugged the cable form my integrated graphics card and plugged it to the GTX (DVI)
I got no signal even after restarting. So I took the PC downstairs and plugged it to the TV using a HDMI cable just to check if the GTX works at all...
It worked fine. I can get signal form HDMI but I still get no signal from the DVI port
if I connect monitor to integrated graphics card (using DVI) it works RELATIVELY fine (I get some green pixels and lines here and there but the image is still transmitted)
if I try connecting the DVI to GTX I still don't get any signal...
My PC knows when to switch graphic cards (before I bought this GTX I used R9 Radeon 270x and I used VGA ports and I could switch between the graphics card without problem) even now when I switch the HDMI (form the tv) between integrated and GTX it works fine and I don't have to change anything in BIOS
all the GTX drivers are updated
so I wonder could the old DVI cable cause this problem (even if it transports image from the integrated graphics card)
or is he DVI port on the GTX broken (I have no other monitors with DVI so I can't test it)
my tv - HDMI
