[SOLVED] GTX 1070 fan not spinning fast
Welcome to the forums my friend!
This sounds perfectly normal, as the fan will not increase based on % load, but on temperature. The GPUs of today can often withstand easily up to 90 degrees. You can adapt this fan behaviour yourself, but with a max temp of 79 degrees, I would not be too worried unless it kept going above this.
I suspect your fans RPM would actually be going up as it approached 80 degrees+.
Reactions: Vnagaravi
