[SOLVED] GTX 1070 GPU Speed at 107% even on idle
Aug 15, 2019
I have tried changing the power to optimal in the nivida control pannel but it did not solve the issue. GPU Tweak II is saying that my GPU Speed is constantly at 107%% even at idle. I can provide screenshots if needed. My card is STRIX-GTX1070. Temperatures and everything else looks fine. I have also done a clean update of drivers.
Here is a link to see MSI Afterburner and GPU Tweak II: https://ibb.co/rQPXhms
Screenshot
D
The FAN SPEED entry in MSI AB is showing ZERO rpm/% of fan speed. 107 is a different value for the GPU, most probably clock, which seems normal.
Like mentioned above, the FAN SPEED entry in MSI AB is showing ZERO rpm/% of fan speed. 107 is a different value for the GPU, most probably clock, which seems normal, IMO.
I don't see any problem with your GPU.
