Hello, -RIG SPECS ARE LISTED BELOW-
Thank you for your attention.
I recently build my first PC! (Yeey).
But.. when playing games like LoL or CS GO my fps is wat lower then it should be(compared to other people's rigs).
With League i start around @ 300/400+ fps and later when the game goes on drops down to a mere 100/110ish...
Also with CS GO on 1080p my fps jump from 100 to 300 all the time, and the funny thing is that when i play on 4k with same settings my fps is still the same (maybe even slightly better).
Now i know that my Cpu is not the newest but it shouldn't be so unstable and giving me so low fps on where others have way more fps in a stable way with even worse rigs.
But when Monitoring with MSI afterburner i saw that in 1080p my gpu only gets a max of 60% usage where my Cpu usage was not above 60% and 65 degrees and my Gpu never geos above 74 degrees.
i ran every test/benchmark saying that my system is either normal or even better than the average person with the sane rigs.
other things i have done with no effect:
tweaked Nvidia settings
reinstalled all de drivers with UDD
Bios Update
enabled xmp profile on my ram speeds (1333mhz)
turned Xbox DVR off
switched my SSD from SATA 2.0 to SATA 3.0
Updated motherboard drivers
i may forgot some but the point is that i done almost everything that i could find and with no effect so my question is,
can you help me!
Sincerly,
My Rig:
- i7 2600 @ stock speeds
- 16gb ddr3 @ 1333mhz (4 slots of 4 gb)
- Asrock z77 extreme4 motherboard
- KFA2/GALAX Geforce Gtx 1070 Sniper EXOC
- 750 watt Be Quiet P10 gold rated psu
- Samsung 750 500GB SSD
- Windows 10 Pro
Bios Update
turned Xbox DVR off
can you help me!
Sincerly,
My Rig:
- Windows 10 Pro
