I recently got a new rig (i7 8700k + GTX 1070) so i tried out battlefield 1. Fps is unstable and in some cases (e.g 64p Operations) it can go as low as 45. I'm playing on 1080p @ 60fps cus i dont have enough bucks for a new 144hz monitor as of writing. It doesnt matter if i play on all Low or all Ultra, the GPU usage does increase if I set on higher graphics but the avg fps remained mostly the same. I've looked around everywhere and tried out everything i can find on the internet (did driver clean installation, re-installed game, changed to "prefer max performance" in nvidia control panel, turned off Xbox dvr, etc.) and nothing seems to work. I tried oc both GPU and CPU but since the problem is from low usage that didnt seem to work.
I have 2x8 gig RAM @3000MHz and it's correctly installed for dual channel (as i can tell from CPU-Z)
When i play on low settings and get <60 fps my GPU usage is mostly <40%, while my cpu usage is around 40% to 60%. I'm using water cooling so both cpu and gpu have ~50℃ so the problem is not from overheating.
Performance in other games are fine, i have ~120 fps in Rainbow six with high/mid settings, ~150 in Overwatch on high settings, ~100 in PUBG and 120-140 fps in Battlefield 4 (which is ironically using the same engine as bf1) on high settings.
Even in menu i have 200 fps while it eats up 98% of GPU but in game it only uses a third. Its been bothering me for almost a month now and i really appreciate ur help. Its my first time posting here so please tell me if im missing out on system info or stuff. Thanks in advance!
My pc specs:
MB: Gigabyte Z370 Aorus Ultra Gaming
CPU: i7 8700k @ 4.3Ghz
GPU: GTX 1070 6G
RAM: G.Skill Ripjaws 2 x 8GB 3000MHz
OS: Windows 10 Pro 64bit
My pc specs:
GPU: GTX 1070 6G
