gtx 1070 ti should I upgrade to a rtx 2080?
Sep 11, 2018
8
I have a gtx 1070ti duke and Im considering upgrading to the 2080 not the TI being they are out of stock and the 2080's are cheaper. I also am running an i5 8400 16gb of ram and a corsair rm series 750w power supply
Upgrading from the 1070ti while having a 1080p monitor will give you no performance improvement and no visual difference. The only difference between the two will be cost.
it's not lacking and currently im using a 75hz monitor 1920x1080. im just the type to upgrade and be minded that i dont have to upgrade for a long while. I would also upgrade my monitor as well if I did upgrade to the rtx 2080
I am getting what i need but id like to upgrade because i kinda want to do a 3 monitor battlestation type build with nothing crazy. im talking 3 27in 144hz monitors that arent 1920x1080
