GTX 1080 2 way Sli, only one overclock while the other stays at default speed help ???
jaber_
Hello,
So as the title says, I have tried using MSI after burner to overclock my cards, and I manage to get one running at 2000MHZ while the other one stays at stock speed 1600MHZ.....what could be the issue ?
I have already selected the option that enables the setting across both GPU
Any suggestions ?
Are they already configured in SLI in nvidia control panel? If so, try breaking SLI in nvidia control panel, then apply your OC to each card, then put back in SLI.
