I have successfully been booting and running my computer without the GPU installed. I installed the drivers for it.
However, when booted with the GPU installed, I see nothing on the monitor (aside from "no signal").
I have ensured in BIOS that the PCI-E is enabled.
This is the build I used: https://pcpartpicker.com/guide/vHD48d/great-intel-gaming-build
MSI (the manufacturer) recommended I use a 650W power supply, but the build says the 550W I have is sufficient.
Faulty cables? The GPU lights up and the fans run... I have tried other ports on the motherboard to seat the GPU...
It's been a great learning experience, but I do want to figure out how to make it work. Any advice would be greatly appreciated. Thank you!
