My GTX 1080 is slowly adjusting my memory usage by how much it thinks I need. I just ran Witcher 3 at 4k UHD and max/ultra settings. According to EVGA Precision, my card only used 2700 MB. I know it's capable of more, because it very slowly adjusted megabyte by megabyte to reach around 2850 MB. This took more than a couple minutes.
EDIT: I was unspecific in the context of my situation. My Witcher 3 FPS can't reach 50. My GPU usage is pinned at 99%, but my memory usage is constantly under 3 GB, never giving me enough juice to have enough frames to match my monitor refresh rate.
Here's what my EVGA precision looks like with Witcher 3 running.
My specs are:
EVGA GTX 1080
i7-5930k 3.5GHz
800W Modular power supply
16GB DDR4 2133 RAM
Windows 10 64-bit
Updated video card drivers
Power Management Mode tested both on Adaptive and prefer maximum performance
Witcher 3 put me at 20% CPU usage (no core was maxed) and 50% RAM usage, pretty sure there's no bottleneck.
Also did a Furmark test. It said I had I was using 8% of my memory, but the GPU usage was capped at 99% and my FPS were only in the 40s. Something isn't assigning the video card enough memory.
I really appreciate your time, thank you!
My specs are:
EVGA GTX 1080
i7-5930k 3.5GHz
16GB DDR4 2133 RAM
Windows 10 64-bit
